I have no Boost or exhaust leaks. Sometimes I hit solid 14 psi and most of the time im running like 6-10psi. Or it will spike 10-14ish then drop to 6.
Ebc. The blitz sbc-id.Do you have a MBC or EBC?
Well there are two outputs one is suppose to be blocked off and the other goes to wastegate. The top is suppose to be feed.Check your "out" vacuum line from the sbc to the wastegate actuator, possibly kinked or loose.
Something similar happened to me, but I had a MBC. The center screw fell out, allowing a random amount of air through.
Yes sir. And like I said even when I uncap the 2nd out it still does the same thing.So you have 1 "feed" and 2 "out" lines?
"Feed" goes to the intake, 1 of the "out" lines go to the wastegate, and the 2nd "out" line is blocked...correct?
I installed it a month ago and wasn't consistent. But I had a exhaust leak at the turbo manifold so I assumed it was that. Well I just fixed the leak today and did a boost leak test and fix three leaks. Now its slower than before lol.1) Was it working before, or did you just install it?
2) Switch the 2 "out" lines and see if anything changes.
3) Did you adjust the gain on the controller? From what I have been reading, when you adjust the gain, it may cause a difference in psi in each gear.
http://www.240sxforums.com/forums/general-tech/130619-blitz-sbc-id-boost-issue.html
^ Are you having similar problem like this person did? I've dealt with only a handful of EBC, so I'm not really keen on 'em.
Yes its adjustable. Wouldn't a boost leak test show it leaking. With the tester I held solid 15psi.wntsum, it could be a bad MBC.
Example, I had a one where you twist the cap. Well, I wanted to go 15psi but the MBC would only allow 12. So I removed the cap and unscrewed the center screw even more. I reached 15psi until the virbration from the car loosened the screw and it fell off, causing random psi changes when I drove.
1Fastr1, You said that you boost leaked checked your car, but is it possible that there still is a leak?
Also, your BOV can slowly be leaking air from the hot pipe when your making boost. Check the vacuum line that goes to it.
Is your BOV adjustable?
Yes I def held 15psi and nothing was leaking. So im starting to think my boost controller isnt working properly.I'd play around with the BOV to make sure it's not releasing air prematurely.
I was just making sure that you didn't have a leak, cause that is what it sounds like. But if you held 15psi, then your definetely good.
Ya I def know its not my wastegate.sounds like it if all is ok with wastegate alone.
