1 - 5 of 5 Posts
joemon
my 91 ka24de all stock the other day while i was driving started misfiring while going home.
symptoms are:
-really rough idle
-great loss of power
-sounds like a sti
-little white smoke out the tail pipe
-little back fire
-kinda smelly exhaust
-no check engine light on
+i checked and adjusted timing back to stock
+getting all spark (but noticed my spark plugs black)
+no arcing in spark plug wires (good)
+dizzy good working order
+coil good working order
+next i pulled plugs out with car on and cyl#4 had no change
+next i checked the injector wire plugs and all were plugged in
+so i pulled each off with car on and again no change in cyl#4
+next i checked the resistants of each plug and plugs 1-3 all resistant except #4
so all testing is pointing to cyl#4 injector...
now im asking is it just the wire bad (power from ecu or ground)
or
bad injector mechanically not in working order..
if its a wiring problem can some1 direct me to a wiring diagram for the wiring of the injector
or
another way to patch this up for now (wire bypass or splicing to another wire)
yes i have searched here and google and other 240sx sites
any help would b nice
-thanx guys
sound like the problem i had on my #1 cylinder
is there any corrosion on the injector plug for cylinder 4? if so just get some contact cleaner, maf cleaner or wire dryer n spray it in there or just unplug it n plug it back in a shit load of times
could be a leaky injector, if so just pull the fuel rail with everything connected n put a rag underneth it n turn the key on to run n check to see if any fuel is coming out
could also be low compression in that cylinder but id check the first 2 first
ok i just swaped my cyl #4 injector with cyl #1 (easier to get to) and now my cyl #4 is working now but Cyl #1 is not working
so i went to pick n pull but the 2 240sx they had all had motors gone out of them.
is there other injectors from other cars i can use that pick n pull will have cars for?
I would go ahead and replace the injector.
Buy a new one or a re manufactured one. Make sure you get a resistance value of 11-14 ohms across ALL injectors.
Edit: don't take the chance of putting a used one in there that you dont know the condition of the injector.
if i were you i would check all your injectors.....pop the fuel rail up and turn the key forward make sure non of them are dripping. i just had to replace 2 of mine..i almost bought use (40 bucks for 4) but i opted to get new...77ish each at autozone. now i have 2 new and 2 old.
1 - 5 of 5 Posts
