1 - 9 of 9 Posts
jesse1378
i got a great deal on a 3 pack of stabilizer bars. its came with the front and rear strut tower braces and a third one..not i know it connects to the engine and then to the body, but i dont know where. does it go on the drivers or passengers side? could someone help me out, maybe post a pic of where they put theirs? thanks in advance...or even tell me what its called so i can search it
Discussion starter · #2 ·
ok i googled some images and all im coming up with is sr20's with the dampner...could someone show a pic of a ka24de with one...it looks like it mounts on the stut tower as well but not sure where to connect to the engine.....with the way this one is made im not sure if the bolts on top of the strut are long enough to put that and the cross stabilizer.
The only time I've ever seen the torque damper mounted on a KA, the idiot ran it to his exhaust manifold cover. That's not the greatest idea because the torque of the motor could possibly cause the the manifold to try to work itself loose. Are there any bolt holes open the driver side of the motor? Usually, this is where you mount the one for the SR. In the spot that usually has the EGR stuff in it.
Discussion starter · #7 ·
the egr stuff is on the passenger side i could try to look around over there. i dont really need it, but it came with it so why not. its not very big, it looks like an engine dampner that i have found on all the SRs but the ends are different. i hope to get out there tomorrow and look around.
1 - 9 of 9 Posts
