1 - 9 of 9 Posts
BOV can go on the hot pipe or cold pipe. It doesn't connect to the turbo, at all. It uses a vacuum source after the throttle body. You might want to do a little research on turbo setups. ;)
i have been trying to research them... i was supposed to have my brohter in law help but he is fucking worthless when it comes to help so now im shit out of luck i have..
1. rebuilt the engine myself
2. changed the diff
3. suspension
4. body work.
5. going to pain it
6. put the engine in and relocated battery
7. installed most everything and re did a few things
now i need to hook up the bov and there is a small hose coming off the back im not sure where it goes and on the hot pipe side of the turbo there is a secondary hose i need to find out where to put that after a few gauges installed my car will be running so for now i only need a how to for the BOV them im cherry if you know of anywhere please let me know thanks!
1 - 9 of 9 Posts
