Guido
im going to be running my redtop with around 11psi on the stock turbo with a blitz fmic, 3.0 dp, 3.0 cat, rsr gt2 catback along with a koyo and flex 210 kit, should i go with a
1- walbro 255lph- reliable or not?
2- denso 290lph- bolt in problems?
3- tomei kit 255lph- is it COMPLETELY bolt in, and is it worth the extra 100 buks over the walbro?
thanks
also has anyone heard any negative things or had good/ bad experiences with the rsr ex mag gt2?
It's kind of weird, sometimes with the walbro you have to use a bigger fuse, I kept blowing the 10 amp, and had to put in a 15 amp, hasn't blown it since, I have talked to a handful of people that have and haven't had to do that.
thanks
The walbro has been so reliable for so many people according to what I've read. I was going to go with the walbro but the thought of the tomei which was made for the car so it is is a true drop-in with no mods made me change my mind to go with the tomei last minute. It's a lot more expensive, but if you can afford it and you want that extra peace of mind the tomei is the absolute best way to go. After blowin a wad of money on my s14sr I decided that the little extra that I spend on the tomei fuel pump is worth it to me. I'll keep you posted.
my walbro jsut came in!!!! :D and a friend of mine ran a walbro with his RB26 swap and 1000cc injectors and he was running rich the whole time (the car is dead now:( RIP Iil GTR :( ) and had no problems at all!
I would've went with the denso - due to the fact that I've heard some scetchy stories about the walbro - but the place i was planning on buying it from won't get a shipment in until the 20th of this month. So I'm going to order the 300zx (VG30DETT) fuel pump from the nissan dealer.
No problems with Walboro... I had it with my KA and have it on my SR and I don't run rich at all.
You wouldn't run any richer with the pump, your injectors are still stock.
I'm just about always signed on, maybe away but I'll get back to you if you leave a message.
