21 - 28 of 28 Posts
most noticeable bang for the buck;
short shifter, or
shift knob and boot, or
ebay stb's, or
ebc green stuff pads, or
high flow test pipe, or
HKS super power flow filter, or
various GOOD car ext. products, or
H4 headlight conversion, or
good fog lights, or
180sx center panel, or
stainless brake lines
best thing for the car;
full fluid/filter change, or
NGK tuneup, or
4wheel alignment, or
rotate/balance&alignment, or
electric fan conversion, or
new large cap. battery, or
battery relocation, or
suspension bushings, or
oil cooler/relocation kit, or
new belts/hoses, or
custom diff oil cooler, or
custom underbelly pans for airflow direction, or
custom brake ducting
A good bit of these had been mentioned. These are some things I could do for way less than $100 or $100 even.
you could probally find used Tein s Techs... they pretty cheap... or go for ebay coilovers... I actually bought the ebay Megan Racing F+R strut bars and they work great.. cost me 90 something i think after shipping...
testpipe is only 50 bux. since i gave a "stupid answer" i'll give a "smart" one for you now. can he get multiple items for you? . i would check the internals for leaks. you could easily replace something with that $100 (clutch master cyl, rubber hoses, brake master cyl, power steering lines, slave cyl, even an oil pan drain plug). as for the strut bars, they don't make a single bit of difference in my eyes. the obx shifter is a pretty damn good bang for the buck, don't get the megan racing one. maybe get some interior dressup. some cool nifty items like a nardi steering wheel (check zilvia's for sale), steering spacer, shift knob, etc. it'd be pretty smart to upgrade a brake component. stainless lines, pads, or some rotors, they're not too expensive. another really smart upgrade would be to pick up some subframe spacers. but the best idea of all, sign up for a track event and start sliding that bitch! (or gripping, whatever floats your boat). 100 dollars isnt that much money at all, but the possibilities are endless.
21 - 28 of 28 Posts
