1 - 9 of 9 Posts
Kat_240sx
I'm almost ready to trow the sr20det in. This is what i have put on it before
the motor swap. Please tell me if i need something els !
Clutch= Spec stage 3
Flywheel= Fedenza
Spark plugs=IRIDIUM
Rear Main seal= Oem
02 censor=Oem from 87 300zx Turbo
Manifold= Megan Exhaust Manifold
Down pipe= Greddy
PS Lines= 1993 240sx
180sx cluster
Mobile 1 Motor Oil
4 Good friends= A case of beer and there good.
Camara to take pics :thumbsup
Am i missing something?
I found that the 87 300ZX Turbo O2 Sensor didn't work for me. I called XAT Racing and they said that they use the secondary 02 Sensor from an S14 on their SR's... I would look into this. Because when I ran the 87 Turbo O2 Sensor, my car ran EXTREMELY rich.
Let me know how it turns out. Right now im running the 87' 300zx o2 and it runs rich, but I dont know if its due to my big injectors since I turned it way down and its still rich . Rich to where its hard to start.
I've already had one. And once I swapped it out for the Secondary S14 O2 Sensor everything was straight. When I say 'secondary'... I mean that on the the S14 there were two O2 sensors... One on the exhaust manifold and one on down the exhaust path. You'll want the one that is on down the exhaust path because the primary one will not fit in the bung. Should work like a charm.
Flywheel= Fedenza
Spark plugs=IRIDIUM
Rear Main seal= Oem
Down pipe= Greddy
180sx cluster
Mobile 1 Motor Oil
Any thing missing?
Tools... And WAY WAY WAY more beer.
1 - 9 of 9 Posts
