21 - 33 of 33 Posts
sr20180sx said:
I got the 17x8 +35 in the front and 17x9 +20 for the back.What tires do you guys think would look good?I am thinking 215/45/17 in the front and 245/45/17 in the back.
the back wheels are 17x9s with 255/45/17:
these arent 5zigens and have a +35 offset tho, not sure if that matters. the tires are not stretched and it still looks good in my opinion.
17x9 +40 = flush?
no
it tucks if anything. don't get me wrong, it's close, but not flush.
keep in mind flushness isn't based on tire flushness, it's all about the wheel's lip being even w/ the fender.
17x8 +35 will fit fine under stock fenders, even w/ coilovers....unless you have pro-dd or something that has a thick shock body... then you might have clearance issues.
oh, and 235/40/17 is quite common on 17x9. if you don't want to stretch your tire, do something sensable (sp?). BUY SMALLER WHEELS. just b/c you have 17x8 +35 doesn't mean you lose cool points.
only stretch your tire if it serves a purpose to your performance needs.
235/40/17 looks GOOD
235/45/17 looks BETTER (imo)
i need info on fitment please.and also tire size you use.details needed.is your car lowered?
jason, what you planning?
17x9 +20?
235/45/17 or 235/40/17 seems to be the easiest to fit w/o pulling the fenders and adding like....-2 camber.
21 - 33 of 33 Posts
