1 - 11 of 11 Posts
hollywood_240sx
Well seeing as I like things that are shaved, I took the stupid and pointless foam spoiler off my car and I need to fill the holes left behind. Seeing as there was no rust, should I spot weld the holes in and risk warping the thin metal, or should I fiberlglass the holes in and make it smooth.
If I do the weld, it will take grinding which could warp the metal if the welding doesn't, and it will also take a bit more body filler to smooth it out.
If I fiberglass, it will take minimal body filler. However the temperature range in my city goes from -40 to 120 throughout the year, not all at once of course, but would the differnce between seasons lead to a crack from expansion?
Fiberglass will most likely crack because the hatch/trunk flexes so much and unless you are really careful everytime you shut it. I shaved the holes in my hatch by welding and grinding, and I used very little bondo. Just go slow and steady.
you weld the holes shut. Cut a square metal plate and weld it on the underside. Then use fiberglass and fill in the holes. sand it down, primer, prep, paint.
I shaved my stupid holes off on my trunk before getting painted.
or you can weld it shut like so, then fill in the top hole with tons of weld. sand down the metal, use body filler, prep, paint.
Alright sounds like this one is pretty unanamous, I have access to a welder, but not for a while. I was just getting a bit ansy and seeing if I could find a shortcut. I can't wait to get my sandblaster working... then you're all in for a long ass thread full of pics.
nrg - that is exactly what I was thinking of doing, just not sure if it was the right way to do it.
Cut out sections up to a quarter inch excess over where the rust ends (to ensure you have cut out all rust and it won't spead anymore). Spot weld plates in where you cut out the holes. Grind the plates and welds down and smooth them out til it's as smooth as you can get it. Take some bondo and fully smooth that bitch out. Done.
Run a full bead if you don't plan to bondo. You won't need any better than a MIG.
1 - 11 of 11 Posts
