1 - 20 of 26 Posts
turbo2forty
I am runnig a sr with a gt28rs FMIC, exshaust, BOV walbro 255, I was gonna get a nismo FPR , How much boost should I run with out doing a fuel injector upgrade? Also I have a S AFC II , I will hook up. Any advice would be great. KEEP IT SIDEWAYS ; EASY OUT
does the S AFC tell you injector duty cycle? If so boost it upto the point where its doing 95% duty cycle, and i would not boost any higher than that.
i have seen ppl with stock MAFS, and stock injectors pushing 270whp, but im sure the injectors are maxing out at that point.
SAFCII doesnt show IDC. Stock 370cc injectors shouldnt be taken more than 14psi on T25 and 12psi on T28. The 28RS is the disco potato, correct? I would maybe only boost 10psi or lower untill you get 550cc Injectors and Z32 MAF.
When I dynoed 272whp, I later found my IDC was 113%. (on stock injectors and stock T28 turbo)
1 - 20 of 26 Posts
