21 - 28 of 28 Posts
LukeDogg316 said:
I'd trust the Megan pulleys. I am rockin' there exhaust system, downpipe, Strut bars and tension rods, and maybe coilovers. Megan rocks, there products are cheap and reliable thus far.
I'm with him...
I have Megan Pulleys... Also have a Megan IC/Manifold/Ext + DP... All have well over 10,000km on them now and I have not had a single problem with any of the Megan Parts.
I'm sure if you compared the Greddy & Megan Pulleys they would the exact same anyway "minus location of the company name etc" so many companies all pretty much use the exact same parts "just re-baged" to their name.
just ignore some of these bench racers on this forums... yeah ur post may be a little funny when u think about it, but some understand your point of view.
Why do people talk shit on forums?? I mean, if some enthusist came up to you and asked a quesiton, are you really going to say "what the fuck is wrong with you"?? Hell no, you'll be considered an asshole or beaten up... simple as 1+1 = 2
Like the above post said, megan is pretty good.. U don't have to get a name brand crank pulley, megan has proven itself not ghetto ..Although i've heard great stuff about them. Get a megan cause its cheaper (slight) to greddy. I have a few megan products myself and very satisified with them.
Im not going to be an asshole and help. The greddy accessory pullies are underdriven and light weight where as the megan pullies are just light weight. Also the crank pulley is made by neither. The crank pully should work fine with the sr because the sr came completely balanced from the factory. There is no balancer on the crank pulley. As long as whatever you replace the crank pulley with is balanced as well you will be just fine. You will also notice a pretty big difference in how your car revs in lower RPMs because of less weight. Personally I don't think the greddy pullies are worth all the money when you can get maybe one or two horsepower less from the underdrive. The only wat the underdrive would help is with the waterpump pulley which would help with the cooling of the motor. Hope this helps.
I would personally stick with one brand. They were all designed to work together. Since pullies are nothing but umm... a pulley lol, you shouldn't have a problem though.
im just speaking out of my ass, but i really dont think light weight pullies will yeild higher WHP. No more than under a low single digit at most.
21 - 28 of 28 Posts
