1 - 10 of 10 Posts
OpTiCz
Apparently no one here has a digital DOHC cluster harness for sale so........
Does anyone have a pinout for both harnesses?
I have an analog installed now, and I have half the digital harness (junkyard cut it off). If I can get a pinout, I'll just attach the front half of this one to my existing one. Any help is GREATLY appreciated.
try putting this in the classifieds...
grab your ankles...
i am asuming that for some reason you want to put a digital cluster in your car, im not going to ask why cause i dont care (its a wasted effort). i am also asuming you have already bought the digital gauge cluster, cause your not trying to buy one here... in the tech section. you have stated that you have the analog cluster installed in your car and you have the leads for the digital cluster.
so i have the following questions for you:
1. why dont you take the analog cluster out, turn it over, look at the "road map" on the back(which btw labels every wire that runs into the cluster), and compare it to the digital cluster?
2. asuming they are different(i dont think they are, but they might be) why dont you use the back of the analog cluster as a referance to wire the digital cluster?
1 - 10 of 10 Posts
