1 - 20 of 27 Posts
TurbLu
Hi guys,
I have been in the build up of a 93 240sx and the previous owner told me that is has vlsd. How can I confirm this?
I'm not sure if that actually will work LongGrain. For the Viscous type diff to lock up, the wheels need to be spinning at a certain speed. The greater the speed, the more resistance the fluid will build up to oppose that movement and eventually it'll lock up. At least to my understanding.
That's why VLSD's are considered sloppy and very slow in reacting (in locking up) compared to the clutch type LSD's.
TurbLu,
Easiest way to check is to jack up the car and look for an orange sticker on the side of the casing.
or (this is straight from NICO)
Check digit 18 in the model # (not the VIN!). <-- the very LAST number in the model ID (which is stamped on the left hand side on the firewall in the engine bay)
For Feb '94 - July '95: A, C, or E, = LSD
F, or "-" = NO LSD
For July '95 - July '96: A, C, or F = LSD
B, D, or "-" = NO LSD
US S13's didn't come with VLSD's. Canadian 91+ S13's and S14's ALL had VLSD's. So if the previous owner had a canadian car, you have a VLSD or he swapped it in.
bring this to an end before things get ugly....
i have a VLSD stock... only if ur s13 is equiped with super HICAS, and yes ur wheels will spin in the same direction when pushed.
-the vlsd is alright, but if the car has alot of miles maybe you should change it.. or at least change the fluid, once the vlsd gets hot, it acts like a open dif.
when i jack my car up and spin one wheel , the other one doesnt even move...its a 93 SE too
where on the subject
so i dont know if i have a lsd... when i start to burn out only one tire spins sometimes both tires will spin and if i do a drif i half to stop before the drift and spinn my tires in 1st to get it to lock up or only one tire will spinn dont know if i have a lsd or what or is it just worn out
its on a 1991240sx.se
I thought if you leave two skid marks when you do a burnout then you have an LSD? 1 mark = normal open diffy?
thats true, but sometimes an open diff can leave 2 blackmarks. but usually one is shorter than the other.
but not everyone wants to do a burnout, so its not the best way to tell.
but yes, check for orange VLSD sticker on the diff. or jack up rear with car in gear and spin one wheel, the other should spin. another way is if your changing your diff fluid, take off the cover and look for an open diff carrier. its easy to spot because youll see 4 gears wide open. if you have a VLSD or clutch pack lsd, it will be enclosed for the most part.
thx laynlow, i didn't realize that even with an open diffy you can leave 2 marks. That's just my ******* way of checkin, hehe.
My S14 has an LSD, I dont know what kinda, but I know its got one, but both tires leave nice long marks when I do burnouts out of my parking place in my apt complex, yummy! I'll take pics next time I do it. The last ones went all the way out of the parking area. I hate my apt complex ^_^
How about this. If you have a 240 in the US and it's NOT a HICAS model then you DON'T have an LSD. The only way you're going to have it is if someone physically swapped it out.
Not true.
I know of 2 240sx's that were SE models that didn't have Hicas, but had VLSD. One was a friend's, the other was FS at a used car lot. And before you ask, this was long before people on this side of the country started doing ANYTHING to a 240sx.
It was an option from the dealership on SE's, as well as part of the handling package on Hicas equipped cars.
1 - 20 of 27 Posts
