So I have come to realize the KA Valvetrain parts aren't very plentiful. So I figured that I'd use my spare time wisely and put together a guide. This thread
will include Cams, Valve Springs, and Valves. I will be divinding the thread into 3 sections.
Also FYI, to my understanding and according to Aftermarket Manf., the stock Valve springs max lift is 9.5mm.
So Let's get started
- SOHC I never forget you guys
Camshaft Section:
DOHC:
Stock Cams -
Manufacturer: Nissan
Duration: 232
Lift: n/a
Type: Intake
MSRP: n/a
P#: n/a
Duration: 248
Lift: n/a
Type: Exhaust
MSRP: n/a
P#: n/a
Performance Cams -
Manufacturer: JWT (www.JimWolfTechnology.com)
Durtaion: 275
Lift: 9.75
Type: Pair
MSRP: $560
P#: A2401-N00S1
Notes: S1 Model
Manufacturer: Crower (www.Crower.com)
Duration: 256
Lift: 9
Type: Pair
MSRP: n/a
P#: 61351-2
Notes: Stage 1
Duration: 264
Lift: 9.3
Type: Pair
MSRP: n/a
P#: 61351T-2
Notes: Stage 2
Duration: 272
Lift: 10.15
Type: Pair
MSRP: n/a
P#: 613512-2
Notes: Stage 3 N/A
Duration: 280
Lift: 10.02
Type: Pair
MSRP: n/a
P#: 613513-2
Notes: Stage 3 FI
Duration: 288
Lift: 10.27
Type: Pair
MSRP: n/a
P#: 613514-2
Notes: Stage 3 N/A Race
Manufacturer: PDM (www.PDM-Racing.com)
Duration: I = 272 / E = 278
Lift: 1 = 9.5 / E = 9.75
Type: Pair
MSRP: $620.65
P#: n/a
Notes: C.702.S Stage 2
Manufacturer: PDM
Duration: 272
Lift: 9.5
Type: Pair
MSRP: $620.65
P#: n/a
Notes: C.702.T Stage 2 Turbo
Manufacturer: BC (www.BrianCrower.com)
Duration: 264
Lift: 1 = 9.52
Type: Pair
MSRP: n/a
P#: BC0211
Notes: Stage 2 Street/Strip
Manufacturer: BC
Duration: 272
Lift: 10.19
Type: Pair
MSRP: n/a
P#: BC0212
Notes: Stage 3 Race
Manufacturer: CrowCams (www.CrowCams.com.au)
Duration: n/a
Lift: n/a
MSRP: n/a
P#: 352900
Notes: From Site "KA24DE SOHC" - IDK which one it's talking about
SOHC:
Stock -
Duration: I = 251/ E = 258
Lift: 10.37
MSRP: n/a
P#: n/a
Performance -
Duration: I = 248 / E = 256
Lift: 10.55
MSRP: $375
P#: A2409-N00S1
Notes: S1 Model
Duration: I = 260 / E = 268
Lift: I = 10.6 / E = 11.02
MSRP: $193.17 + $250
P#: n/a
Notes: C.406
Manufacturer: PDM
Duration: I = 268 / E = 272
Lift: I = 11.02 / E = 11.17
P#: n/a
Notes: C.404.H
Manufacturer: PDM
MSRP: $264.98 + $250
P#: n/a
Notes: C.404.H-T
Manufacturer: PDM
Duration: I = 300 / E = 300
Lift: 12.65
MSRP: $327.56 + $250
P#: n/a
Notes: C.411.H
Manufacturer: ANTRX (www.ANTRX.com)
Lift: n/a
MSRP: n/a
P#: n/a
Notes: R6
Manufacturer: ANTRX
Duration: I = 288 / E = 292
Lift: n/a
MSRP: n/a
P#: n/a
Notes: R5
Manufacturer: ANTRX
Duration: I = 270 / E = 270
Lift: n/a
MSRP: n/a
P#: n/a
Notes: R4
Duration: n/a
Lift: n/a
MSRP: n/a
P#: 352900
Manufacturer: HybridKA (www.HybridKA.com)
Duration: I = 270 / E = 272
Lift: I = 11.07 / E = 11.2
MSRP: $185
P#: n/a
Notes: Stage 1
Duration: n/a
Lift: n/a
MSRP: n/a
P#: n/a
Notes: Stage 2
Manufacturer: CourtesyPArts (www.CourtesyParts.com)
Duration: 270
Lift: 10.05
MSRP: $300
P#: 13020-00001
Notes: Hi-Performance
Lift: I = 13.75 / E = 14.07
MSRP: $300
P#: 13020-00003
Notes: Race
Valve Spring Section:
DOHC:
Stock Springs -
Max Lift: 9.5
LBS: n/a
Type: Single
MSRP: n/a
P#: n/a
Performance Springs -
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: n/a
P#: AKA24-DSPRR
Notes: New Version In Development
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: n/a
P#: 68188-16
Notes: n/a
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: n/a
P#: BC1010
Notes: No Machine Work Required
Manufacturer: R/D (www.RDValveSpring.com)
Max Lift: 11.25
LBS: n/a
Type: n/a
MSRP: Call
P#: 350-N
Notes: n/a
Manufacturer: Ferrea (www.Ferrea.com)
Max Lift: 12.5
LBS: 254
Type: Dual
MSRP: Call
P#: S10043
Notes: Requires Retainers (E11021) & Seat Locators (SL1064)
Manufacturer: SuperTech (www.SuperTechPErformance.com)
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: Call
P#: n/a
Notes: n/a
SOHC:
Stock -
Max Lift: n/a
LBS: n/a
Type: Single
MSRP: n/a
P#: n/a
Performance -
Manufacturer:
Max Lift: n/a
LBS: n/a
Type: n/a
MSRP: n/a
P#: n/a
Notes: n/a
In The Proccess of being updated
Valve Section:
DOHC:
Stock Valves -
SOS: 0mm
Type: Intake
MSRP: n/a
P#: n/a
SOS: 0mm
Type: Exhaust
MSRP: n/a
P#: n/a
Performance Valves -
SOS: .5mm
Type: Intake
MSRP: n/a
P#: 97458I-8
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: 97458E-8
SOS: .5mm
Type: Intake
MSRP: n/a
P#: BC3210
Manufacturer: BC
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: BC3211
SOS: 0mm
Type: Intake
MSRP: n/a
P#: F1835P
SOS: 0mm
Type: Exhaust
MSRP: n/a
P#: F1837P
SOS: 1mm
Type: Intake
MSRP: n/a
P#: F1836P
SOS: 1mm
Type: Exhaust
MSRP: n/a
P#: F1838P
Manufacturer: SI Valves (www.SIValves.com)
SOS: .5mm
Type: Intake
MSRP: n/a
P#: 13201-53F00H
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: 13202-53F00H
SOHC:
Stock Valves -
SOS: 0mm
Type: Intake
MSRP: n/a
P#: n/a
SOS: 0mm
Type: Exhaust
MSRP: n/a
P#: n/a
SOS: .5mm
Type: Intake
MSRP: n/a
P#: 13201-40F00H
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: 13202-40F01H
Updated 9/26
**Also any info on stock specs would be greatly appreciated, also if any other performance valvetrain parts are found, plz share them with us
Camshaft Section:
DOHC:
Stock Cams -
Duration: 232
Lift: n/a
Type: Intake
MSRP: n/a
P#: n/a
Duration: 248
Lift: n/a
Type: Exhaust
MSRP: n/a
P#: n/a
Performance Cams -
Durtaion: 275
Lift: 9.75
Type: Pair
MSRP: $560
P#: A2401-N00S1
Notes: S1 Model
Duration: 256
Lift: 9
Type: Pair
MSRP: n/a
P#: 61351-2
Notes: Stage 1
Duration: 264
Lift: 9.3
Type: Pair
MSRP: n/a
P#: 61351T-2
Notes: Stage 2
Duration: 272
Lift: 10.15
Type: Pair
MSRP: n/a
P#: 613512-2
Notes: Stage 3 N/A
Duration: 280
Lift: 10.02
Type: Pair
MSRP: n/a
P#: 613513-2
Notes: Stage 3 FI
Duration: 288
Lift: 10.27
Type: Pair
MSRP: n/a
P#: 613514-2
Type: Pair
MSRP: $620.65
P#: n/a
Manufacturer: PDM
Duration: 272
Lift: 9.5
Type: Pair
MSRP: $620.65
P#: n/a
Duration: 264
Lift: 1 = 9.52
Type: Pair
MSRP: n/a
P#: BC0211
Manufacturer: BC
Duration: 272
Lift: 10.19
Type: Pair
MSRP: n/a
P#: BC0212
Notes: Stage 3 Race
Duration: n/a
Lift: n/a
MSRP: n/a
P#: 352900
SOHC:
Stock -
Lift: 10.37
MSRP: n/a
P#: n/a
Performance -
Lift: 10.55
MSRP: $375
P#: A2409-N00S1
Notes: S1 Model
P#: n/a
Notes: C.406
Manufacturer: PDM
P#: n/a
Notes: C.404.H
Manufacturer: PDM
P#: n/a
Notes: C.404.H-T
Manufacturer: PDM
Lift: 12.65
P#: n/a
Notes: C.411.H
Lift: n/a
MSRP: n/a
P#: n/a
Notes: R6
Manufacturer: ANTRX
Lift: n/a
MSRP: n/a
P#: n/a
Notes: R5
Manufacturer: ANTRX
Lift: n/a
MSRP: n/a
P#: n/a
Notes: R4
Duration: n/a
Lift: n/a
MSRP: n/a
P#: 352900
MSRP: $185
P#: n/a
Notes: Stage 1
Duration: n/a
Lift: n/a
MSRP: n/a
P#: n/a
Notes: Stage 2
Duration: 270
Lift: 10.05
MSRP: $300
P#: 13020-00001
MSRP: $300
P#: 13020-00003
Notes: Race
DOHC:
Stock Springs -
Max Lift: 9.5
LBS: n/a
Type: Single
MSRP: n/a
P#: n/a
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: n/a
P#: AKA24-DSPRR
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: n/a
P#: 68188-16
Notes: n/a
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: n/a
P#: BC1010
Max Lift: 11.25
LBS: n/a
Type: n/a
MSRP: Call
P#: 350-N
Notes: n/a
Max Lift: 12.5
LBS: 254
Type: Dual
MSRP: Call
P#: S10043
Max Lift: n/a
LBS: n/a
Type: Dual
MSRP: Call
P#: n/a
Notes: n/a
SOHC:
Stock -
Max Lift: n/a
LBS: n/a
Type: Single
MSRP: n/a
P#: n/a
Performance -
Manufacturer:
Max Lift: n/a
LBS: n/a
Type: n/a
MSRP: n/a
P#: n/a
Notes: n/a
Valve Section:
DOHC:
Stock Valves -
SOS: 0mm
Type: Intake
MSRP: n/a
P#: n/a
SOS: 0mm
Type: Exhaust
MSRP: n/a
P#: n/a
SOS: .5mm
Type: Intake
MSRP: n/a
P#: 97458I-8
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: 97458E-8
SOS: .5mm
Type: Intake
MSRP: n/a
P#: BC3210
Manufacturer: BC
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: BC3211
SOS: 0mm
Type: Intake
MSRP: n/a
P#: F1835P
SOS: 0mm
Type: Exhaust
MSRP: n/a
P#: F1837P
SOS: 1mm
Type: Intake
MSRP: n/a
P#: F1836P
SOS: 1mm
Type: Exhaust
MSRP: n/a
P#: F1838P
SOS: .5mm
Type: Intake
MSRP: n/a
P#: 13201-53F00H
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: 13202-53F00H
SOHC:
Stock Valves -
SOS: 0mm
Type: Intake
MSRP: n/a
P#: n/a
SOS: 0mm
Type: Exhaust
MSRP: n/a
P#: n/a
SOS: .5mm
Type: Intake
MSRP: n/a
P#: 13201-40F00H
SOS: .5mm
Type: Exhaust
MSRP: n/a
P#: 13202-40F01H
Updated 9/26
