Welcome.
I'd love to see your S14, even in stock form.
I too started out with an automatic S14 that went through the manual swap.
Transmissions:
1. I would keep an eye out on the marketplace here, facebook marketplace, facebook groups, zilvia, and wherever else for an S14 5 speed transmission.
Any from 1995-1998 should work. That would be your easiest option.
2. You can use an S13 5 speed transmission, however the S14 has a crank position sensor on top of the bellhousing if I remember correctly.
So you would either need to drill some holes and install it onto the S13 bellhousing OR you would have to also buy an S14 manual transmission bellhousing and install that onto the S13 trans.
It's not the worst thing in the world to do, but that's why I recommend finding a manual S14 transmission.
3. You can use an Sr20 transmission with an S14 bell housing. You can't use just any sr20 transmission though, it has to be from a Silvia/180sx ( basically some form of S13 or S14). There was the Nissan 200sx that was a front wheel drive car with an Sr20, sold in the US. You can not use that one. You still end up with having to swap the bellhousing though even if you find one.
These are your options. You can not use the manual transmissions from the 90s nissan altima, those are front wheel drive cars and won't work. The nissan frontier also had a ka24 and had a manual transmission that MAY work, but those transmissions are shorter. Your shifter would need an extension to make it back to the factory hole in the 240sx. You would also need a custom driveshaft made up. I'm not even listing that as an option for you to do because the driveshaft alone probably costs what an s14 transmission would cost you.
Keep browsning the internet, you WILL find an S14 trans.
Transmissions:
