Ok so my 240 ka24e was running good but until 2 weeks ago the motor has been shaking quite a bit. I recently purchased the vehicle did a full tune up changed the spark plug and wires got a new valve cover gasket and changed the engine oil and the car passed the california smog test with no problem. Now sometimes when i try to start the car it wont turn on unless i keep pressing on the gas pedal n then if i dont keep pressing on the gas pedal the car will shut down sometimes n when it idles it goes from like 900 to like 500. i did a test today i plulled the spark plug wires while it was on and every wire i pulled out made a difference in the car n made the car shake alot more. I remembered once that I was messing with the injectors and that made the car run like s*** the car was super shaky so i moved the injectors and the car started to run good again. The car runs good at high RPMs i feel no loss of power at all just when im not pressing on the gas the car shakes and sometimes it dosent want to start today I was also messing with the injectors n it didnt want to turn on then I moved the injectors n it turned on. Please help I need to get her running good again
