1 - 4 of 4 Posts
Does anyone have any idea why my ka24de 240 is be misfiring
. Could be tps or coolant temp sensor leaky injector
Check your tps first and then change your coolant temp sensor
Disconnect injector 1 by 1 and see which cylinder has no change I say it could be an injector leaking
I've had my 240sx since 1995, and anytime I've had a misfire, it's been the injectors.
Check the impedance on each of them. From what I just looked up again, each of them should be between 11-14 ohms.
Start with spark plugs and work your way to the distributor and make sure all cylinders are firing. If spark checks out, check fuel system for any blown o-rings, leaks, etc.
1 - 4 of 4 Posts
