9.0:1 Compression???
7.9K views 49 replies 14 participants last post by  i_Go_SpLaT
Whats the advantage of 9.0:1 Compression?
Whats the Power level obtainable with 93 Octane?
How much boost is able to be produced with 93 Octane?
Ive tried discussing this with my friend and he always says how going 8.0:1 would be better because of able to use higher boost levels and HP levels off 93 Octane gas. I keep reminding him that my car is going to be used for a drift and so so drag car in the near future. Ive always understood that 9.0:1 would yield more torque. Going 8.0:1 would be too lagy IMO with an SR20. I keep telling him that im looking for a power level of between 350-400whp. He says 400whp isnt able to be achieved with the stock 8.5:1 compression on 93 octane. I know people out there make over 400whp on the stock compression with 93 Octane. Please break it all down for me.
if you run 9:1(dont use de pistons) you will have to back the boost off, so much so that it will negate installing 9:1 pistons in the first place. if you wanna make 350whp, buy a 2871, some stage 2 cams, injectors, headgasket, etc. and you'll make 350whp.
Ya 9:1 not bad. Just get it tunned. The higher the compresion with boost , you need better gas. Thats y they come factor with 8.5:1 of somthing like that. so you wont have to run race gas every day.
rossfashow said:
cant you yeild more hp with higher compression even if you lower the boost?
dumb ass did you not read my post? the sr makes power because its boosted, not because its 2 litres. since you can dump more air into the motor with 8.5:1 pistons there is no reason to change the compression ratio. go to c12 or c16 and its a completely different story.
Actually a 9.0:comp would yield the same HP levels with lower boost and have better torque. Say you go with the 8.5 comp running 22 psi on the 9.0 comp you would only have to run 17 psi for the same out come. You can run 9.0 comp pistons on the street with a proper tune it has been done many a times. As long as you have the tune you can run it. I personally don't like to run 9.0, but a lot of guys do. I just like to have the buffer so if you get a bad batch of gas you are still safe. However a 9.0 would be a good comp for drifting since your torque curve would be more favorable even with a small turbo installed. If there is nothing wrong with the motor though why bother in tearing it down just to bump the comp. Now if the motor was bad that would be another story...
I was asking for when i do tear it down to build it stronger later down the line. Just doing some research. Thats all. Now my research tells me to keep the stock compression when i go to rebuild. Thanks for the help guys.
your right stubby but we're talkin pump gas here.
I completely disagree.....
Is that why my KA-T makes more power than your SR on pump gas with only 12 PSi with a T28? Stock 9:1 compression! Your splitting hairs on gas 8.5:1 and 9:1 are not far enough off to make a compression relative to gas difference.....Think about what you say before you say it..... i could see 9.5:1 using a toulene mixture or race gas but 9:1 compression does not warrant anything more than High test gas......
An SR with 9:1 compression ratio will not yeild enough to be worth it though, due to lack of displacement and stroke......(well unless your plan is to build a monster)
Sorry Geist... I think you should fly your broom for yourself....
awh the noob read the post about rocket fuel and thinks he knows what hes doing, how cute. im about to flame your ass and its your own fault. yes your ka-t makes more power than an sr at 12psi(as it should), but it has little to do with the 9:1 compresion ratio and more to do with the extra half litre you have on the sr(for those of you who want to split hairs i know its 2.4 litres not 2.5, but the sr isnt exactly 2 litres either. poor noob, paid some to build him a car and thought it made him special. i think you should join that other guy on his broom or would you like me to find you your own?
LMAO...You wouldnt happen to know who gave you the stupid stick would you?
Well If you havent seen it yet here it is mr picture!
Fuck your broom!
If im not mistaken, im not the first one in this thread to tell you you were wrong....
PS. You dont allways have to be right, no matter what your daddy told you!
wussmonster said:
read what you wrote puresx, you're wondering why your motor which is .4l larger and has a T28 makes more power than a 2.0l w/ a T25....hmmm.
it's because he has NAWSS stickers and neons installed, with a flux-capacitor relocation kit and a turbocharged rotary v8 intercooler
pffft. when did engine size count?
I know what i wrote.....I guess retorical questions dont come through very well on the net?
(thats a retorical question please dont answer):thumbsup
Regardless compression does have to do with boost relativity just not splitting hairs about needing race gas with 9:1 compression on an SR....
