1 - 3 of 3 Posts
so once again, not posting where i want but oh well, it won't let me finish the account set up. anyways, i got a pretty stock sr20det redtop in my hatch, my a/f ratio stays at 15.2 or so at idle and at cold start will jump around between 14 and 16 and too my knowledge thats normal. When i am on the throttle all is normal, after giving it gas and letting off the throttle completely it jumps up to 22.4, not sure if it is an install error or if i actually leaning out for no reason? I usually throw in the clutch and give it some gas and it will read normal. so yeah, idk what the problem is. :frown:
240-kid
That's normal. On decel it cuts the injectors therefore no fuel is being injected in turn the gauge reading max as it reads nothing but air passing buy no fuel.
240-kid
Also to gain access to the rest of the forum you need 10 posts. 7 more and you should be good.
1 - 3 of 3 Posts
