1 - 3 of 3 Posts
Ok I have searched and gotten some good ideas, but none really match my problem. so here goes. did my tranny swap, auto to manual. everything is great, except for...i got some grinding between ALL gears. the tranny is supposed to be from a 97 with 64k miles. so it should be good conditon. already adjusted the clutch and even put it up on jack stands, and the wheels don't move at all with the pedal pushed in. so i know it is fully disengaging. i put penzoil synchromesh in and but it still grinds, its only been 1 day though, does it need time to adjust? HOWEVER, it DOES NOT grind at all when downshifting. only going UP through the gears. It can't be all the synchros right? the grind is not even audible really, it is more just felt through the shifter. it feels like any other car would grind, there is just no sound. any ideas?
your slave might not be going all the way out and in, checking out, bleed the system and replace. If that doesn't work, fill your tranny with redline, that shit kicks ass
you may have completely dead synchros. if you end up needing new ones, i have a full set of good ones. but check the slave and bleed the entire system.
1 - 3 of 3 Posts
