1 - 2 of 2 Posts
I am stumped. I have a KA24DE with a bad Auto Transmission, it only clicks when trying to start. just replaced starter and ignition starter switch. would a bad tranny cause the engine to not crank? Any help would
be greatly appreciated. Thanks
Is the battery good ? As in had it tested to make sure its okay ? Could be bad battery connections too. Unless the transmission is locked up and keeping the engine from spinning, a bad trans won't cause a no start. Since you hear a "click" you can rule out the neutral safety switch. If everything checks out, put a socket on the crank bolt and make sure the engine can turn freely, if not, then the trans might be locking it up or you have a seized up engine.
1 - 2 of 2 Posts
