best *Functional* spoiler for drifting?
7.7K views 54 replies 20 participants last post by  HOOKSH
Ok, i have been drifting a little lately and notice that i'm drifting to far out of the turns. I know this may be some technique and tire issue (i have kumho touring tires) but i was wondering what is the best functional spoiler that will provide downforce for staying tighter in the turns. Looks really don't matter, i'm going for function.. Thanks in advance
that's why i'm asking, i said i think it may be a technique and tire issue but i was just wondering what is the best functional wing
i think u just need to practice your control better. Turn the wheel sooner and dont be turning too much always does it for me. I dont think any wing would help, they only create downforce at high speeds. I think its better to have good control over it than having a piece of alum or CF restricting you. yo where in VA do u live?
ok well i can see nobody actually understands the question so i guess i'll just forget about this post...
WHAT'S THE BEST FUNCTIONAL SPOILER?
Answer: Do suspension
Like saying., What kind of car do you drive?
Answer: Tomato Soup
#15 · (Edited)
something like this:
might actually be functional. i stumbled upon it (on the SCC website) while looking for something with google awhile back (i forget what). it might actually provide too much downforce at certain times, as rally is different than drift. it probably costs a lot too. just an idea though. at this point i really dont think you should be worrying about which wing is best for drift though, as you dont really need one. id focus on becoming a good drifter first.
thanks for that, i will check out autoimaging, i didn't see your post until i went back through...thanks...
drft_07 said:
no prob, and boro i'm not sure about that rally car wing, lol
"So a decade from now, when you see a pimply faced Kentucky boy gluing a segmented rear wing to the rear hatch of his tired old RSX, you can tell him that idea first appeared at the 2003 Rally Monte Carlo. That was the first race for Subaru's updated aero package, which in addition to the new-generation Impreza nose, includes a rear wing with four vertical slats sticking through it. The design was such a good idea that three races later, in New Zealand, every one of the top cars had a similar wing.
The slats, you can explain, are there to improve high-speed stability by maintaining downforce when driving sideways, and by using the wind to help push the tail back behind the nose.
As the wing pushes through the air, the air following the top surface of the wing gets flung upward. Newton says the air's job, when being pushed up, is to push back down on the wing. On the bottom surface, the opposite happens; with the wing surface suddenly pulling up, air is sucked up to take its place, and when that happens, the air pulls back down on the wing.
Slide into a corner at a 30-degree angle, though, and two things happen. First, the wing is effectively narrower to the air approaching it. Second, the cross section of the wing, carefully designed in the wind tunnel for optimal downforce, gets elongated, taking some of the violence out of the air's journey upward.
Violence is everything when you're dealing with air, so the no-longer optimal cross section of the wing means less downforce.
The slats force the air to straighten out and go across the wing as the team aerodynamicist intended. All the air slamming into the side of those four slats, plus the two end plates, also work to straighten the car out, much like the vertical stabilizer on an airplane.
If he's still standing there, don't expect Kentucky boy to believe you. The wing, he'll slowly and carefully explain, since obviously you don't know much about cars, is there for the ladies."
-Dave Coleman
I don't know if Rally driver's call it drifting or not, but it looks similar when they slide around a U-turn for example. I think the rally spoiler will be helpful, but I'm pretty sure that is only true if you are going higher speeds.
For Drifting: I would recommend the Rally spoiler because it is designed to create loads of downforce in turns, etc. Then again, I've never seen one for sale... Those GT wings should work fine though.
Also, DLS is right, a spoiler will only help downforce at around 60+ mph.
Please correct me if I'm wrong
Johann
