So I have been on the site ever since I bought my 1993 hatch back in July of 09, and so I figured it was time to start a build thread.
so here is the list of parts I have and I plan to buy/install in the next year or so....let me know what you think
Yellow=stuff I have and have installed
White=stuff to come later
Suspension:
• Tein mono flex coilovers
• Tanabe Sustec Sway Bars (Drift Spec) S13 front
• Circuit sports suspension arm package
• Circuit Sports aluminum subframe bushing
• Tein Tie Rods
• Circuit Sports Adjustable Rear Lower Control Arms
• Circuit Sports Adjustable Front Lower Control Arms
• Greddy Strut Bar 89-94 FRONT
• Greddy Strut Bar 89-94 REAR
• Nissan 240SX Tie Rod Dust Boots
• Tanabe Sustec Sway Bars (Drift Spec) S13 rear
Drivetrain:
• ACT Xtreme Plate Clutch w/6puck Sprung
• MISHIMOTO REPLACEMENT STARTER FOR SR20DET
• Agency Power Steel Braided Clutch Line
• NISMO Clutch Fork Pivot for 5-Speed Nissan
• Nabco Tokico Clutch Master Cylinder 5/8 Nissan 240SX
• Nismo 30620-RS520 Clutch Slave Cylinder
• Kaaz SAN2655 1.5-Way Limited Slip Differential
• Nissan 240sx/Silvia 89-98 One Piece Aluminum Drive Shaft
• B&M 45088 Short Shifter for 1989-1998 Nissan 240SX S13/S14
• HKS 27006-AN001 Shift Return Spring Kit SR20DET
• 300zx front and rear brake conversion
• Ichiba 5Lug Conversion for 89-94 Nissan 240sx
Engine bottom end:
• Darton Sleeves
o CP Pistons
o Manley Turbo-Tuff Rods
o ACL Race Bearings
o New OEM Front Cover/Oil Pump
o Mazworx main stud kit
o ATI Damper
o GReddy Hi-Capacity oil pan
o New OEM timing chain components
o New OEM rear main seal
o New OEM oil pickup
o Nismo Pilot Roller Bearing
o Clean R/R oil ports
o Oil groove machining
o Sleeve install
o Bore & Hone w/torque plate
o 1/2" headstud machining
o 19mm rod bearing machining
o Resize line bore
o Check/Polish/Balance crankshaft
o Custom step deck block
Engine top end:
• Mazworx Race Head
o Supertech 116lb dual valve springs
o Supertech Titanium retainers
o Supertech valve guides
o Supertech Inner valve spring seats
o Supertech +1mm oversized valves. (Exhaust valve will be inconel)
o New OEM Nissan rockers
o New OEM guides
o Tomei cam gears
o Tomei Solid Pivots
o Tomei 280 camshafts
o Mazworx 1/2" headstuds
o Mazworx 90mm grommet headgasket
o Clean R/R Oil Ports
o CNC combustion chamber 90mm
o Stage 2 port and polish (gasket match, bowl work, blend and polish)
o Competition valve job
o R/R valve guides
o 1/2" head stud machining
o Resurface head
o Grind rockers for dual guide conversion
Fuel Delivery:
• Greddy 13920503 Top Feed Fuel Rail SR20DET
• GReddy 13500072 720CC Top Feed Peak Hold Universal Fuel Injector
• Tomei 185002 Fuel Pressure Regulator Type S
• TOVIC FUEL PRESSURE GAUGE 1/8NPT
Turbo/Air Induction:
• Precision Turbo PTB205-5128B 76 Trim Turbo
• Greddy 11920200 Air Intake Suction Kit S13 SR20DET Using Z32 MAF
• Greddy 13522319 Intake Manifold Plenum S13 SR20DET
• DIF 10081 N15 Pulsar Throttle Body Adapter Plates Complete Kit
• Tomei Exhaust (Turbo) Manifold for Nissan SR20DET Silvia S13
Engine Electronics/Management:
• FRS Apexi Power FC + Datalogit SR20DET RB25DET RB26DETT Combo
• Splitfire DIS-004 Direct Ignition Upgraded Coil Packs
• 5Zigen Pro Racer ECON Ignition Voltage Booster
• Greddy Profec B Electronic Boost Controller
• Blitz 19565 SD Exhaust Gas Temperature EGT Racing Meter
• Garrett Turbo Mechanical Boost Gauge
• AEM 30-4100 52mm Gauge Type Wideband UEGO Controller
• HKS 41001-AK009 Type-0 Turbo Timer
Cooling:
• Mishimoto MMRAD-S13-89SR Aluminum Racing Radiator
• Mishimoto Radiator Fan Shroud for Nissan 240sx S13 89-94 w/SR20
• Mishimoto Racing Thermostat for Nissan 240sx SR20/KA24
• OEM Nissan SR20DET Water Pump
• Greddy R-Spec Intercooler kit S13/S14 SR20DET 12020402
• Greddy SR20DET Oil Cooler Kit w/Remote Oil Filter
• Samco Coolant Hoses for SR20DET
• Circuit Sports S13 Aluminum Coolant Overflow Tank for Nissan 240sx 89-94
• Redline Water Wetter
• DME 403001 Nissan 240SX/180SX Stainless Steel 3 Piece Cooling Panel
• DIF Dual Electric Fan Controller
EDIT: Pictures are soon to come!!
Suspension:
• Tein Tie Rods
Drivetrain:
Engine bottom end:
• Darton Sleeves
o CP Pistons
o ACL Race Bearings
o ATI Damper
o Sleeve install
o Resize line bore
Engine top end:
• Mazworx Race Head
o New OEM guides
o Tomei cam gears
o R/R valve guides
o Resurface head
Fuel Delivery:
Cooling:
