1 - 5 of 5 Posts
New here, but not new to cars :p
I just picked up a bone stock 92 coupe se. So far I am very happy getting out of the fwd/honda game.
My question: I have shaky hard stops, wobbly lane changes, loose steering (basically handles like a school bus on flat tires). I understand that I need to change the tension rod bushings. The problem i am also seeing is severe camber wear on the front tires. Is this camber wear also a symptom of the t/r bushing being blown? or should I be looking elsewhere? The other bushings are all stock and worn but not junked like the t/r.
Any advice would be helpful thanks...
Also has anyone used those 5$ camber bolts from spc?ebay?
also if wobbly stops check your brake rotors
1 - 5 of 5 Posts
