Car wont go into gear
8.2K views 22 replies 12 participants last post by  darcnytemare
Car wont go into gear please help
ok so as the title says im having loads of trouble gettin my rb25 tranny into gear. At times i have to just try each gear until i get one to go in then it will normally go into first or second gear with some force. i checked the master cylinder and its full so i kno im not leakin fluid. So anyone got any ideas ?
You mean while the car is running? Like while you drive it? The clutch adjustment could be incorrect as well. If it is too tight, your clutch will be in all the time even when you press down. You adjust id down by the clutch pedal. Try that first. Then, could be slave or master cyl.
My rb20 tranny is weird sometimes. When its first starting out and I pull outta the garage in reverse, it has a hard time engaging into reverse rarely( a common Nissan problem I believe). But I"ll put it in first and then put in reverse and engages no problem, seems really odd but still works!
My KA tranny did the same thing, your probably right s14-240, WHAT THE HELL NISSAN!
my ka does it as well into reverse, takes a good reving while in N sometimes to get it into reverse, i feel like an idiot when new ppl are in my car and i am struggleing to find reverse.. lol
My buddies dsm does it too, and my friends fwd 200sx, and his geo tracker. It just the way lots of them are. The newer trannys where you have to pull up on the ring to put it in reverse eliminate it. Also, vdubs have never had that problem, as you have to push down on the shifter to go in reverse.
LoL wow that really reminds me of a time when I saw a guy in a parking lot! I was backing out of my stall and he was directly behind me backing out as well and I saw his face looking behind him, waved him to go first. I guess he had it in first instead of reverse and smoked the guy in front of him hahahaha then I stalled my car cuz I was laughing so friggin hard
usualy on manual boxes most car manufacturers wont syncronize reverse hence the hard to get into feeling when trying to shift into reverse from neutral.
putting it in first will line up the reverse gears tho, so if it doesnt want to go, try first then reverse.
else try a right nasty scolding, sometimes works.......
yea I have that same issue with tryin to get it into gear on my mustang. Unfortunatly for the reverse issue, i have to put it into 5th then pull it into reverse or else itll bang into gear...its supposed to unlock the reverse gear without having to force it in and not destroy the syncro or grind the gears(ahhh..the genious minds over at ford). I dont have that problem on my 240 though...well because its an automatic as of right now.
