Car cranks but wont turn over
man i feel sick to my stomach after my car just shut off after doing a tune up on it
ok so i did replace spark plug spark plugs wire.
distributor cap and rotor while doing that the bolt for the rotor striped and is busted so i went to advance auto parts to get a replacement bolt for it they say they didn't have to i just got a m5 bolts at the bolts and nuts section so went back home replace the dis. rotor and just the m5 bolt connection back and went to go turn it on it crank once then everything shut off after that i tryed to crank it again there was no sign only dims barely lights and when i turn the key the light shut off clock and what not and there no sign
i can turn on the wiper and the dome light cant turn on the or pop up the healight also the sealtbelt doesnt even move
PLEASE SOME ONE HELP ME FIGURE OUT WHAT HAPPENED AAHHH i feel bad because it started and what not before i did all this
P>S i have a ka24e 1990 240sx
UPDATE: ok so i tryed to see if it was something wrong with the battery so i went and got my battery pack connected it and then went to turn on ok everything is working headlight and and whatnot so i tryed to crank it again after doing that it was cranking but only 2 to 3 time then it stops.... im stuck at now...
