1 - 7 of 7 Posts
yeah. i could get more from australia but i wanna know others that will work. how do i place a 28 pin in the 32 socket board. bottom it out like placing it in a programmer? thanks.
ooo opps, i ment 32 pin. any 32 pin should work, sorry its been a loooong time since I used a PLMS board or those style chips in general. My new boards use PLCC chips which are small and square :greddy:
27C256 and 27C512 will work, but they are UV erase, so you will need to get an UV light.
The am29f010 should work... its 8bit and 32 pin, dont see why it wouldnt, but make sure you get the right style ie:
AM29F010-120PC AMD FLASH 32-PIN PLASTIC AM29F010 - eBay (item 220287226958 end time Apr-26-09 08:54:29 PDT)
and NOT something like:
30 - AMD Am29F010-90JC, 1 Megabit 128 K x 8-bit Flash - eBay (item 350186608300 end time May-03-09 14:36:38 PDT)
The later are PLCC chips, which are actually the exact same as the ones I am using right now.
So short answer, yes, I think any of the 29F010 chips should work as long as they are 32 pin, hold enough data, and are the proper physical format.
Try Ebay..
I use Intel Flash P28F010-90
We were getting rid of a couple tubes of them at work.. so a couple tubes disappeared from the dumpster ;)
1 - 7 of 7 Posts
