Complete sohc engine/tranny part out
429 views 11 replies 7 participants last post by  DriftX
All pieces are best offer. Shoot me a p.m. with what u think they are worth.
89 sohc 5 speed partout:
Motor had 134k miles, ran very strong, no oil burning issues
JUST ADDED: Fan Shroud, power steering pump and resivoir/line, exhaust manifold.
I have:
All the intake tubing pieces
Maf sensor
stock air box
K&N filter and adapter
Throttle body
Intake manifold
stock cat
Cyl Head
Whole bottom end
Brand new alternator with 25 miles on it
UNCUT sohc wiring harness
2 sohc 5 speed ecus
3 distributors
2 coil/ignitors
fan shroud
a/c lines and pump
new coolant temp sensor
ka flywheel - used, not sure what shape its in
shifter assembly
motor mounts
CUT sohc wiring - only cut to fuse box connections, would be good to repair a broken ecu plug or elsewhere
2 spare dash plugs
where you located?
i need a GOOD oil pan with no warpage or dimpled bolt holes and possibly the bottom end. can you shoot me a PM with a price?
motor mounts good? and how much for the tranny where you located ?
I'm located in Franklin NC 28734.
Motor mounts look fine.
Not sure on the tranny, just shoot me a price, I need it gone.
Sometime next week I'll pull apart the bottom end and check the conditions of the crank. It didin't have any vibrations or anything, but Ill mic it for you and let you know how deep the grooves are.
Still got the tranny. It's in great shape! No grinds and drove with no clutch slippage! let me know!
Sure I'll sell the complete head. Shoot me a PM with an offer.
Bump, need this stuff gone.
Just PM me with an offer and ill let you know.
