Sounds like compression is all good, 155 is spec, but the main thing is that all 4 cylinders are making the same numbers.scka24e said:did a compression test on mt SR and got 150 on all 4 cylinders with 3 cranks and no throttle, been getting mixed answers on it , what do u guys think lmk
Yea, plus in the original post you said you only went 3 cranks, go 10 at WOT and I bet comp would be right on the money.Rs4Race said:ditto . your throttle body is supposed to be wide open and you would probable get at least 155 if you did that. but if they are close to 155 and all even its good.
