Alright guys I just corner weighed my car at my shop.
This is a bone stock base model 91' 240sx hatchback.
Full interior and spare except for the back seats which have been removed.
RB25DET with mckinney mounts, driveshaft and downpipe
Koyo radiator
2 12" electric fans
Greddy Manifold
GTR FMIC with mild steel piping
Trunk Mounted battery
Removed front Bumper Support
Removed Entire AC system and Heater Core
1/2 tank of gas
Open Downpipe
Car weighed in at about 2660 lbs
Cross Weights were close to 50%
Front to Rear was 54% - 46%
Apparently the problem is not the weight of the motor but the position of it. Basically 1/3 of the motor sits in front of the axles which is what makes a difference. The only thing to fix this weight wise is to move weight in front of the axles to behind the rear axles. Hood, Fenders, and Bumper weight is negligable. Only thing worth losing weight on is the fmic and the pop headlights. Any weight within the wheels will not affect front-rear balance.
Suspension wise, you would have to use some higher spring rates in front than normal to compensate. Hence affecting weight transfer and front to rear body roll, which in turn affects the way the car handles corners
-Bluefire
Koyo radiator
2 12" electric fans
Greddy Manifold
1/2 tank of gas
Open Downpipe
-Bluefire
