Disclaimer: I, nor 240sxForums.com, will be held responsible for any problems, broken pieces, or inability to perform the described directions. This is your vehicle, and your decision to weld the differential. You solely are held liable for the work you do and any injuries or problems that may result from your inability to perform these directions properly. Please don't read this as it will fail (refer to the synopsis) but this is just to cover the forums' and my own ass from having people come after me for their fuckups. Thank you.
There are four separate posts on the removal, welding, and installation of the diff. Each section has its own individual post and they are in order to ToC below.
Table of Contents:
Synopsis and Tools List (You are here)
Removing the Pumpkin (Link to Individual Post)
Prepping and Welding the Differential (Link to Individual Post)
Putting it All Back Together (Link to Individual Post
Synopsis:
I have welded several differentials and have yet to hear of an occurrence of any of them breaking. The write-up below is the procedure I have performed multiple times as by others I know. My friend currently has a rb26 s14 with a differential I welded for him over one year ago. The car has 630whp, is a daily driver, and is beaten on constantly. The differential still has not broken. I say this to reinforce that if you weld and pre-treat the differential the same way I do, you will not have to fear broken welds.
Please post comments on this write-up as well as your thoughts/suggestions/questions/troubleshooting/etc.
Tools and Materials:
12mm Socket
14mm Socket
17mm Socket
Pipe (to put in wrench for more torque taking off the bastard bolts)
Big ass hammer
Flathead Screwdriver
Mig Welder (at least 55A output, recommend 110 at min)
Chisel (or sharpened flathead)
Stop Blocks (or something to stop the car in front of the front tires)
2 Blocks for the wheels to sit on when raising the car
1 or 2 Painter’s Buckets (Deep Buckets wide enough to rest output shafts on)
RTV Silicone (Blue Letters)
Brake Cleaner
1.5 quarts of Gear Fluid (at least 75w-90)
Time:
1/3 of Day if you piss around. Whenever doing it I always have hangups taking it out and putting it back in. Plus between eating lunch, threatening to kill friends, it takes some time. But it's fun, pretty easy, and worth it.
***Also, thanks to Kevin (KB240SR) for letting me use his differential to take pics of while welding it.***
Table of Contents:
Synopsis:
12mm Socket
14mm Socket
17mm Socket
Big ass hammer
Brake Cleaner
Time:
