dyno results
1.9K views 23 replies 13 participants last post by  s13goingsnail
:thumbsup i went to the dyno today and heres what i got
N/A: 150.8 HP AND 159.6 TQ
75 shot: 220.9 HP AND 309.1 TQ
14.5 drift said:
Wh3r3 is your mod list? Clutch and nitrous doesn't giv3 you 150 to the wh33ls N/A. :nono Watcha workin with homie.
96 ka with my old 91 exhaust cam, cone filter , muffler, accel wires zex plugs, no egr, and that is it
14.5 drift said:
coo coo, your car might benefeit pretty good with a cat back. Nice band though.
meagan racing cat -back is on the way :thumbsup
yeah i today i ordered a 300xx mafs and the meagan exhaust hopefully i will have them installed before the 27th which is when we are going back to the dyno
if you look at the nitrous graph my torque falls off fast at the top end because the engine is starving for air, it should help balance out the torque curve ,if anything it will flow alot better then the shitty 240 one
NissanDriven240 said:
would this effect normal driving n/a? Or would it be a plus for both worlds
it will be a plus for both :thumbsup
heres the cost of the mods i have
zex kit: 500
zex plugs : 25
bottle heater : 125
370 injectors : 100
balancing and bluprinting of injectors : 140
around 900 bucks , not bad
GlacierFreeze said:
He gained around 150 ft/lbs of tq (peak) off of a 75 shot... that's crazy...
yeah at first i though he said 209 , then he repeated himself and i still didnt believe it till i saw the graph, i actually hit 315 ft lbs on the 1st run spraying but it broke up too much at the top so i had to take a little back
