Ok so when this first happened I was driving home and the throttle felt very snappy when barely pressing the throttle. As I noticed this random thing happening it randomly backfired like crazy and started jurking very hard on steady throttle. Holding the gas on idle steady would sound line a rotary. From the point on I have been working on this situation and replaced these listed below
Here is a link from when I did these (instagram)
www.instagram.com
When I did those things at the time the car did not want to Idle on cold but it would rev instantly and then when it warmed up it would idle but the rotary sounding acceleration would happen again so I replaced these
Here's the link when I did these parts after (Instagram)
www.instagram.com
After doing those the car idles and won't die when it's cold. The throttle response is faster but it's still doing the weird rotary sound when you are steady on the throttle.
I have 4 parts on the way, a new distributor, a new maf sensor cause my maf in it rn is some cheap ebay crap, a new ignition coil and some new spark plug wires.
so I'll update what happens when I install those, but In the mean time If anyone has any ideas of what it might be I would love help cause I have no cars to get to work rn I'm borrowing co workers crap lol.
I would also like to say It ran perfect up until this and I had recently done a head gasket and did the intake manifold gasket and aac gasket and with that like I said new fuel injectors
- coolant temp sensor
- put a higher octane in, running 91 now
- Brand new fuel filter
- cleaned the maf
- new spark plugs
- recently did new fuel injectors a month before this problem
- New 02 sensor in exhaust manifold
@240sx.vic on Instagram: "Pls read: changed coolant temp sensor, cleaned maf, put higher octane gas and changed filter and now the car idles perfect, but giving it gas makes it cut out and bog. When the car is cold it doesn't want to idle but giving it gas is instant and won't cut out or bog when revving. Anyone have any ideas? Maybe throttle position sensor or vacuum leak?"
@240sx.vic shared a post on Instagram: "Pls read: changed coolant temp sensor, cleaned maf, put higher octane gas and changed filter and now the car idles perfect, but giving it gas makes it cut out and bog. When the car is cold it doesn't want to idle but giving it gas is instant and won't cut...
- new fuel pump
- new fuel pressure regulator
- new throttle position sensor
- I replace a hose from the intake that goes downwards, it had a cut in it and lost coolant and then I found a possible hose connection from the back of the intake into some lime faceing the back of the fire wall that I saw on youtube cause i couldnt find where it would go anywhere.
@240sx.vic on Instagram: "Update: changed fuel pump, pressure regulator, found where a unknown vacuum hose goes to, replaced coolant hose that was ripped that goes into the intake manifold, replace throttle position sensor and it's running ok-ish, Still running rich though even though I changed coolant temp sensor and it wasn't but now it is. However it's misfiring, so maybe the maf is bad. I did clean it and it did nothing"
@240sx.vic shared a post on Instagram: "Update: changed fuel pump, pressure regulator, found where a unknown vacuum hose goes to, replaced coolant hose that was ripped that goes into the intake manifold, replace throttle position sensor and it's running ok-ish, Still running rich though even...
