I meant front mounting these factory intercoolers on a S13.
The one on the right is a 1GGTE (GA70 Supra)
The one on the left is a 7MGTE (MA70 Supra)
As you can see they are both bigger than the factory s13 silvia front mount and they can be sourced for dirt cheap. It was a suggested upgrade option, not an invitation for argument.
At low boost applications they will not increase lag by a significant amount. There is obviously some terminology confusion here. I was referring to these type.
one of which i have installed on my car. They are a cheap and easy to install mod for a mild tuned car. I wouldnt recommend them for SR's with huge turbos and precise tuning though.
Yes they do. Whether they send the bled signal back into the intake side is a different matter. Most aftermarket solenoids send the unwanted boost signal back into the intake. Some bleed valves do this too but most dont, sending the signal to atmosphere. But in the end both a bleed valve and a solenoid work by altering the boost signal to the wastegate.
Our club has about 60 Silvias, 180sx's and 200sx's with the SR20DET and front mount intercoolers. Most of these cars do regular track work, Motorkhana, qtr mile runs and long cruises and overheating due to a front mount installation has never been an issue on any of them. The fundamental design of an intercooler is for air to flow through it as easily and quickly as possible. On a properly designed front mount there is plenty of air flowing through the intercooler to go on and cool the radiator.
I you have cooling problems it would be a better idea to upgrade the radiator rather than get rid of a frontmount intercooler.
You seem to be pretty confident that your guesswork is accurate.
