ok. i dont know if you guys know but when the KA24de is low on oil the lifters and cam start to make a rattling noise. well mine is making that noise, kinda sounds like the chain rattling.
anyway, i check the oil its full, i check the oil pressure and is normal, i pull the valve cover off hoping that none of the shims or lifters has come out and are floating the motor and nothing. I checked all the bolts to see if any where loose yet again normal. I checked the timing chain and guides to see if they where loose and you guessed it NOTHING.
Any ideas on what might be making this thing rattle? the only thing i can think of that i cant test at the moment is that after the motor rebuild the valves have just set into place and the clearence on the shims is off. but i cant check it right now cause i dont have my feeler guage.
If anyone can scratch there heads and com up with something Please let me know cause i cant thinkof anything. the car is parked untill i figure it out cause i dont want to cause any more damage then might allready be done. and i need the car ASAP so if you can help i would apreciate it.
the car is NA btw
the car is NA btw
