I built this KA year ago. It was complete buld minus pistons and rods. Original engine had 17k on it (i checked that once i did a carfax on it...still have it).
I spent nearly 2k+ on it with all Nissan parts. Have ALL recipts for parts and mashine work(done by reputable shop www.abacusracing.com )
what it has :
Ported and polished head(exhasut and intake side only intake shown).
Valave job and new valve guides and resurfaced(cost me 4xx still have recipt)
Block was honed and decked.
Cometic head gasket
ASP crank pulley
Nissan thermostat.
Crank micro polished
Valve lash adjusted (was out after valve job)
ALL new Niaan tentioners chains and guides
New seals...obviosly
Ported intake manifold
OEM nissan bearings and rings(nearly 3xx for all that)
Engine was ballanced(pistons,rods,crank,asp pulley,fidanza flywheel)
Flywheel not included but i will give it to you for only 300 WITH SPEC clutch(same 8k miles)
COMPRESSION NUMBERS:
210 206 208 211
I DO HAVE PICS but not till i get home.
There is more, but i am at work dont cant remember all of it.
I want to swap RB20DET but if i cnat get enough money for this i wil have to keep it.
I am hoping to get 800 for it but if you have an offer and i will consider it NO LOWBALLERS
what it has :
Cometic head gasket
ASP crank pulley
Nissan thermostat.
210 206 208 211
