Fuel Door won't open
2 reading
8.1K views 1 reply 2 participants last post by  si2die4
Tried searching around for 240sx Fuel Door with not much luck. Went to the gas station this morning. Went to pop the fuel door, and nothing. Won't open at all.
Is this a common problem with the s13 240's? Is there an easy fix? Is there another way to get the door open?
Thanks
Had the same problem, you can get to the switch/pin from inside the trunk. Just reach back there are you will figure out how to open it. It could be there it too much slack in the line or that it needs to be adjusted. Once you get it open you can remove the plastic nut holding the pin in there, pull it out, and inspect it. I have the entire cable/latch/pin setup for sale if yours turns out to be trash.
Good Luck
