Check the vent line. It goes up to the charcoal canister under the hood. If its pinched shut, any fuel vapor/pressure will stay in the tank causing a pressure build up. I would either remove the charcoal canister and see if the problem persists, or crawl under it and make sure the lines are good going to the canister.
