first off wierd KA hesitation, STILL!
it happens randomly but much more often when engine is at operating temperature
did some more checks today and pulled the plugs:
all of the plugs were fine but plug on clyinder number 2 was covered in oil!
not oil fouled but just thin clean oil all on the threads
apon further inspection there seems to be a bit of oil on the cylinder head
all the other plugs are okay
looking down all the other clyinders clyinder number 3 looked like a bit extra carbon ontop of the piston
but now! when I hesitate I had my friend driving behind me and he said it just smelled like unburnt fuel
the wires are good and the gap is okay but im thinking someone is causing clyinder 2 or 3 not to fire under WOT sending the smelly HC threw the cat and out the exhaust.
did a dry compression test and they all came out 165 across the board
warmed the engine up and checked exhaust color and its not black or white so its not burning coolant or running very rich.
I'm going to do a clyinder leakdown test tommorow and see how it goes but can ayone else offer any other places to look? here is the list of new or fully functioning parts:
02 sensor
engine coolant temp sensor
fuel filter (z32)
3" catco cat
NGK iridium IX plugs
NGK wires
newish cap/rotor
alternator
battery
starter (irrevilant but it was replaced)
probably a few more things but they sliped my mind.
but when my KA gets power, it roars but when it doesnt its smelly and slow.
I'm thinking now that:
the valve guide maybe worn
valve cover gasket
blowby but i would have noticed it with a comp test
plug seals ( I was told this by another tech, but I don't see anything resembling that in the FSM)
02 sensor
fuel filter (z32)
3" catco cat
NGK wires
newish cap/rotor
alternator
battery
valve cover gasket
