Ok, here is the situation.
My wiring burned up. I replaced the entire cabin harness, and the entire engine bay harness. The harness from the engine bay that came out didn't have the blue clip with the bolt on it that seems to go through the firewall, but the new one does. I've installed both, with a few questions about where some of the connectors are (The engine compartment harness is routed, but there aren't things to plug in to near the fuse block). When I apply power, nothing happens. Absolutely nothing. If the key is in the ignition I got a CLICK and then nothing when power was applied. I'm sort of at a loss here. There is no brown connector near the fuse block to hook anything up to, and the black connector beside it is at a loss as well. I'm close to having everything else connected (All of the lights and that kind of crap).
Any suggestions?
In the military, they have a series of signs. One of them is "cover me, I'm fu*ked."
Someone please, help me.
