I couldnt find it on here I found it on phase2motortrends site but no pictures. So I thought I would share.
How to set your timing to 15*
1. Remove coils and valve cover.
2. Set motor to TDC its the second tic from the left and your 1st cylinder cam lobes will be facing away from each other.
3. Remove the cas. You will see two dots on the gear and a mark on the shaft. (see picture)
4. Line up the dot on the right with the mark on the shaft.
5. push the cas all the way in. When you press it in the gear will rotate and the mark on the shaft should line up with the dot on the left now. It might be a little bit off rotate the cas to line up the mark with the left dot.
6. Tighten up the cas and recheck the marks line up. Your cas should be aligned to 15* now.
7. Put the valve cover and coilpacks back in.
Again this information was taken from the www.phase2motortrend.com faq page I just took pictures and put the information on here.
