AHH, I have resoldered the same connection for my ignition wire 4 times and I can NOT get it to work right.
My car pops under heavy load/boost, so i have a weak ignition connection as confirmed by hotwiring it to the battery (ran fine like that).
I have my purple/white wire tagged into my thick white wire off my fuseblock like it should be.. it's soldered and everything. The car starts up wonderful, cuts off quick with the key, idles smooth and all, but will still hiccup under boost.
So I am asking, is there another spot i can try to re-do this wire, or do i have to run it to that white wire? I'm not sure if that wire is pulling enough current how i have it connected. Any input or ideas would be appreciated!
