Welcome to the forum.
Congrats on getting your car, please post some pics.
So I'm going to give you a little bit of unsolicited advice because you need it.
This is the same advice I would give any young guy regardless of who it is.
That car weighs around 2800lbs and has like 200hp, maybe a little more or less.
It's plenty to get you in trouble.
What I recommend is doing some track days with it.
Put new tires on it, put new brake pads and flush your brake fluid.
Make sure your engine oil, coolant, transmission oil, rear differential oil, and powersteering fluid are all replaced and at the proper levels.
Go to a track night in america event.
Spend some time in your car and learn it's limits.
You will find out soon enough where you want to modify it.
You'll want better wheels/tires, brakes, suspension and some gauges/electronics.
There's a phrase out there that goes like "Make your car stop, turn and go"
The tires/brakes make it stop better.
The suspension will make it turn better. (There's a lot of parts that I am just lumping together by saying "suspension")
Then FINALLY, you want more power. Power is useless if you can't control it.
Building a car is all about the whole package. It's about doing things in an order that makes sense logically.
If I snapped my fingers and your sr20 magically is at 400 hp, I guarantee you that it will result in a crash.
The stock180sx isn't designed for 400hp. It's designed for 200hp at the crank which is like 160 at the wheel.
Please don't make the same mistakes I did.
Don't do dumb stuff on the street.
Don't hurt yourself/others or potentially worse.
Don't spend a lot of your youth trying to fix things that shouldn't have broken in the first place.
For the love of God don't overbuild your car either.
The point is that you want to drive it.
