I got my car dyno tuned at AutoLink this saturday
I was on the dyno for 2 and a half hours...
Here are Results With 91 Octine :eek3dance
Base Line Run @ 9psi
270.7 = HP
236.5 = TQ
Top Run @ 16psi
355.6 = HP
336.7 = TQ
My Mods:
Fuel System:
New Walbro 255 l/h FP
New 555cc Tomei injectors
New Z32 fuel filter
All new fuel hoses
Engine:
S14 zenki SR20DET
Fully rebuilt at BlackTrax Performance (blacktrax.net)
New Greddy 1.2mm head gasket
New Arias 86.5mm pistons
New Eagle H-beam rods
Stage 1 ported and polished head
Engine Bored 0.5 mm over
Magnafluxed, professionally cleaned block
Micropolished crank
New Nissan factory crank bearings
New heavy duty rod bearings
New front/rear seals
New thrust washers
New Nismo lower temperature thermostat
New Tomei Rocker Arm Stoppers.
New Greddy Valve Springs
New HKS Iridium spark plugs
New HKS step 1 cams
New ARP Head Studs
New Greddy aluminum pulley kit
Z32 MAFS
Freshly reground valves.
Brand new valve shims
New HKS Super Mega Flow
New Nismo Motor Mounts
Custom engine torque dampener
New Greddy Oil filter temperature adapter
New Greddy radiator hose water temp. adapter
New vacuum lines
Transmission/Drivetrain:
New B&M Short Shifter
New Trust shift knob
New Spec Stage 2 Clutch
New Stainless steel flexible clutch line
Clutch dampener removed
Engine Control:
New Greddy E-manage
Turbo:
New Apex'i AX53B60-P25 (fast spooling track racing turbo.)
New XRP stainless steel braided oil and coolant lines.
Skyline R33 GTR front mount intercooler. Factory black, custom mounted.
Custom 3" intercooler piping, flat black.
Intercooler piping are all BEADED,
TurboHoses.com 2-ply fiberglass reinforced silicon turbo hoses for all connections and transitions.
New Heavy duty T-Clamps all around
New HKS SSQV
New Greddy Profec E-01 turbo controller
Exhaust System:
New Stainless Steel Exhaust Manifold
Greddy Turbo Extension
New Blitz 3" DP
New Enjuku Racing 3" Test Pipe
New Flex section.
New Blitz Realize TT 80mm exhaust system.
270.7 = HP
236.5 = TQ
Top Run @ 16psi
355.6 = HP
336.7 = TQ
My Mods:
Fuel System:
New Z32 fuel filter
All new fuel hoses
Engine:
S14 zenki SR20DET
Micropolished crank
New thrust washers
New HKS step 1 cams
New ARP Head Studs
Z32 MAFS
New vacuum lines
Engine Control:
New Greddy E-manage
Turbo:
New HKS SSQV
Exhaust System:
New Blitz 3" DP
New Flex section.
