1 - 7 of 7 Posts
Im sure its just a wiring thing somewhere, but has anyone experienced their hazards and turn signal fuses to put when putting them in? just curious
sounds like it is grounding out somewhere...or the ground has no contact. Are you putting the right amp size fuse in?
if he is blowing a fuse, he has grounds in the wrong spots.. commonly known as a short.
Check you are using the correctly rated fuse.
start chasing wiring via the FSM wiring diagrams.. look for a short to ground from the positive lead...
The hot is grounding or the grounds are bad, ie a short=blown fuse
Discussion Starter #6
Hey,
yea im putting the right fuse in, but they are jsut poppin, I just got the car from some guy who messed with all this stuff i assume, the engine bay sure looks like it, hah. So i have to cleanup his half%$# job. Im going to have to check the grounds then.
thanks
try changing the flasher
it could be the combination switch as well
1 - 7 of 7 Posts
