i would adjust the outer and inner rodends the same but to where it as closely resembles the stock length. to figure out the length it will be measured from the center of the rod end holes not from end to end. this way you know it will be adjusted right. and when you get it aligned take the instructions up there with you and they should use it as a guideline to get it set properly. if you have any more questions please ask on here or pm me.
