1 - 14 of 14 Posts
Does anyone know anything about Ipod touch / iphone synced with the ecu? Maybe correspond with Boost, AFR, egt? I've looked around and the only thing i saw was for OBD-II models.... I have 93 hatch and it has the OBD-I.....
Yeah i noticed that... the answers i was searching for was if the rb25det have OBD2. They don't. Thus i cant use my touch = need to buy gauges... T_T
i dunno...gauges are kinda pricey and dual purpose abilities of using an ipod for both would be cool.
My question is, could you hook it up to the stereo, get gauges, and do diagnostic work all at the same time?
woa, I just bought an ipod touch and I really was considering getting some obd2 software for my laptop so I can diagnose problems with obd2 cars. can someone link me to the setups where I can use the ipod???? I would really like to at least see whats out there. thanks.
Discussion Starter #8
yeah it called REV. and innovate has one that comes out this month. but since RB25dDET isnt built with either obd-1 obd-2, i cant sync my touch. Just wondering, i mean why not use resources and maybe next thing you know. Ipod touch / iphone could be the next stand alone...
There is no way the iphone is powerfull enough be be a standalone, point blank.
Thanks for the info on the obd2 reader things. Im wondering if they come with software so you can use it with your wifi laptop as well. I read up on them a little last night but I was too tired to read as much as I would have liked to.
Anyways, if your 25 is a r34neo, I can tell you without a doubt you can hook up a consult port. If it isnt what is keeping you from using a z32 ecu and just changing like 4-5 wires??? Many rb people are doing this all the time.
Discussion Starter #11
Wow really? thanks on the info about the z32 ecus! but then doesnt that mean you have to re map the whole z32 ecu? sorry noob question, havent looked into z32 ecus nor the basics.
nope, no remapping. get a 95 or lower turbo ecu and youll need to run 370cc injectors and a z32 maf though. If you have a 25 neo it will also controll the vct! The 25 neo is consultable though anyways but its commen for rb guys to run the z32 ecu because they can run the z32 maf without retuning and the ecu is easier to come across in the states in case your ecu went bad.
There is also like 5 wires you need to change up on your ecu pinout, easy! I can help you with that if you need but I got to get in bed. I have a drift event tomorrow early.
Discussion Starter #13
I'm plannin on getting an rb25det. i was going to get mine from jsamotors. where can i find an rb25 NEO?
1 - 14 of 14 Posts
