1 - 13 of 13 Posts
Does Anyone know if the sohc fuel rail will easily mount/fit on the dohc intake? I want to swap to top feed injectors, but the aftermarket rails are $$$. Has anyone tried it or will I be the first?
Thanks
No it won't line up...
The Intake ports are spaced different
The Project Silva one fits great
Discussion Starter #8
Cool, I'll try that when I have money. $75 isn't bad, but $65 shipped is even better. Thanks for the help.
yup.. that's what I'm here for.. and occasional verbal harassment...
Discussion Starter #10
Hey now, I need to know for my 11:1 compression, E85 Turbo plans. I sized injectors at 770cc/min minimum. I hope i can get it all done this summer. I'll probably have some ? for you about the E85 setup stuff later.
Well, if you plan on doing 11:1 compression and a turbo, you better have a great fuel system...
E85 is easy...
Discussion Starter #12
Yeah, I plan a 10 gal fuel cell between the rear suspension and the passenger seat. Custom lines to the filter and FPR up to return less rail. only thing I'm worried about is my range with just a 10 gal tank.
When I converted to E85 on my 240, my Range went from 300 miles to about 225...
E85 requires 30% more fuel than gasoline, so quick match would tell you your range will drop 30% from what it would be with gasoline
1 - 13 of 13 Posts
