Kinda sounds like a fuel pump. See if you can check fuel pressure.
Yeah, That's what my shit is doing. I'm going to try and find a replacement wire that burnt up some fucking how.. and check my voltage. I hope it's just this wire that's not letting enough current thru to keep the car up to par.I would check the voltage of your battery with the car off, then with the car on. See the difference in the voltage so you know how much voltage the alternator is putting out. My bad alternator caused sputtering at random times like that. It seemed to act up after I would drive and let the car sit then drive again.
