car is having problems...thought i could fix it myself if i can.
the car's front lights don't go down no more, i changed the relays and they still don't work. they only open up...why is that? can it be the motor or switch?
car engine started to make noises, since i changed the oil and added oil treatment...sounds louder than ever, seems like the chain is loose or the valves are loose, what do you think?
car tranny oil was replaced with red line gear oil 75w90, for some reason 2nd gear lags, it doesn't pick up as fast as usual, why?
and the tail light fuse keep on dying on me? i have to use a 30a fuse instead of the 15 and it will still die on me sometimes, it seems like the cluster lights are linked with the tail lights and the side markers, because if that fuse is dead, all those lights die with it...why?
any kind of advice would be appreciated. thanks guys
